Produsul este nou, in cutie cu toate accesoriile, nu a fost montat.
PRET 700 lei.
0722340642
Se potriveste la:
2002-2006 Mini Cooper S / Works
Guaranteed to increase horsepower
Designed to improve throttle response and engine sound
Replaces entire factory air intake system
Not legal for highway use in states adopting California emission regulations
Washable and reusable lifetime air filter
Lasts up to 100,000 miles before service is required (depending on driving conditions)
Easy to install, usually in 90 minutes or less
K&N Million Mile Limited Warranty®
K&N 57i Series induction kits are specifically designed for each different vehicle and will free your car from the size restriction that comes with the factory air box. These economical kits can take a variety of different forms based on vehicle characteristics and available space under the hood. Each kit is designed to provide power throughout the RPM range. The extra surface area of these open-air air filters provides even more airflow at lower restriction than a K&N O/E replacement filter which is limited to the size of the factory air box. The larger air filter also captures and holds more dirt increasing its service life before a cleaning is required (up to 100,000 miles). The filter is either directly attached to the engine carburetor or throttle body or indirectly through a tube assembly running from the filter to the engine. All adapters are made from high quality materials such as steel, aluminum, silicon or reinforced nylon to ensure long life.
instructiuni instalare:
http://www.knfilters.com/instructions/57-0463_inst.pdf
Kit Admisie Filtru Sport K&N 57i Mini Cooper S 57-0463
Sablare si PowderCoating - reconditionari jante, etrieri, etc
Da-ne un like pe Facebook
http://www.facebook.com/SRZPowdercoatingCustoms
Re: Kit Admisie Filtru Sport K&N 57i Mini Cooper S 57-0463
600 lei !
Daca doresti ofer 600 lei si ne vedem maine.
